3D Chamfering?
3D Chamfering?
colinNPU8N
3D Chamfering?
colinNPU8N
Hi guys, I'm trying to do a 3D chamfer as per https://forums.autodesk.com/t5/fusion-360-computer-aided/3d-chamfering/td-p/5958904 although by using sideways compensation and adjusting radial and axial stock (as per video) leaves me with a failed tool path and
"Error: An unexpected error occured."... Nice and cryptic as always Smiley Very Happy
I've simplified the curve to a single line to try and get at least something generated, but still wont have it.
Centre sideways compensation generates a tool path, but obviously means I cannot apply radial stock offsets...
Ideas?
LibertyMachine
Could you export and share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
colinNPU8N
OK, finally figured it, the video is now null and void for the current fusion version. Ignore stock offset completely and use only chamfer.
Colin
