3d Adaptive unexpected behaviour
designingberlin
designingberlin
I have a little issue I don't understand. The screenshot shows an adaptive toolpath. Mostly with the expected stepover. Just in the center the stepover is increased and I just don't know why. Any ideas.
f3d file is attached
  • The stock is the actual casted part
  • The body in the manufacturing setup is the final part
  • The adaptive toolpath is contained within a closed sketch contour
Any ideas?
Stefan
a.laasW8M6T
Its most likely removing an island of material
the stepovers going around corners like that look incorrect but you must remember that the toolpath is from the center of the tool, the width of the material being cut isn't larger than the optimal load.
If you look at the toolpath running in simulation you will see it is likely correct
designingberlin
Yes. I checked that. tool load is fine. I ran the production parts like that.
It just seems very unexpected. I thought there might be a deeperreasoning behind that behaviour. Usually adaptive toolpath make a bit more sense to me.
programming2C78B
It's because its milling a "triangle", not a rectangular shape. It will never voilate the max stepover, so it IS expected.
Please click "Accept Solution" if what I wrote solved your issue!
