3D Adaptive Smoothing Error - April 2020 Update
26-Taylor
26-Taylor
Has anyone else been getting this error since the April 2020 update? I'm seeing it on every 3D Adaptive toolpath I have, regardless of smoothing tolerance & whether smoothing is enabled or not.
Thanks for any input!
seth.madore
Well that's interesting. Can you share a file that is showing this?
Seth Madore
seth.madore
I'm seeing this in my own files. I've logged this as CAM-21519, sorry for the inconvenience!
Seth Madore
evanp4509U4JZ
I got the same thing Thursday and again this morning.
26-Taylor
Thanks for looking into this @seth.madore , I'm looking forward to a solution/explanation.
Thanks again!
-Taylor
5X-machines
I was about to post about this exact issue. I'm having the same problem on every single 3D adaptive I do with smoothing.
I did get the warning to disappear once but I had to turn smoothing all the way down to a couple tenths.
redcapjuice
I also had to really tighten up smoothing to get the error to dissapear.
I just don't know if smoothing is then disabled, or what is happening when I post WITH the error. I'd rather not risk it.
