3d adaptive rest machining
CRANDALLPRECISION
CRANDALLPRECISION
Can anybody see why this toolpath will not regen?  If its deleted and the ops under it are deleted it will make a toolpath. If you delete and make the toolpath then drag it up under the drill it will not.
setup 8 adaptive toolpath
a.laasW8M6T
Hi
This seems to be a problem with rest machining from previous operations not correctly transferring to that last setup.
I see there is an empty setup at the top that defines the stock, If I delete that and define the same stock in the next setup it works.
Also for the Last setup you effectively have a relative size Box with no additional stock left after the other facing ops so you could just change your stock to that instead.
@seth.madore is there a limit to how many times the stock can be transferred down operations?
CRANDALLPRECISION
Yes just duplicated setup to try different stuff. Yes that works, it generated the first time around but when he changed drill depth op went dirty no matter what we did. However after deleting the empty setup he can do whatever with the drill depth and will generate.
