3D Adaptive: Adjusting safe distance for minimum retraction?
feklee
Message 1 of 8
feklee
The popup for Retraction Policy states for minimum retraction: "Moves straight up to the lowest height where the tool clears the workpiece, plus any specified safe distance."
The safe distance looks OK in the preview. Still I would like to know:
Where can I adjust the safe distance?
Replies (7)
Message 2 of 8
danielGHB4Z
+1. Did you ever resolve this? As I also need to adjust the Safe Distance.
Message 3 of 8
a.laasW8M6T
It appears there is no safe distance for 3D Adaptive, the tool tip is the same as for other 3d toolpaths which DO have a safe distance parameter like 3D Contour etc.
Andrew Laas
Senior Machinist, Scott Automation
Message 4 of 8
feklee
I haven't use Fusion in ages, and I'm not sure if I ever resolved this.
Message 5 of 8
seth.madore
No, there is no "Safe Distance", only the built in 2mm** that exists "behind the scenes"
**that's going off of memory, but I may be confusing it with the internal 2mm value that also exists in 2D Adaptive
Seth Madore
Message 6 of 8
danielGHB4Z
Apologies @seth.madore looks like the magic number I'm having issue with is called safe height. Must be a different thing.
Message 7 of 8
seth.madore
Oh, that's a combination of your Height settings. If you share your part or a screenshot of your Heights tab, we can guide you further
Seth Madore
Message 8 of 8
danielGHB4Z
I was able to brute force a workaround by reducing the Axial Stock to Leave and instead increasing the Bottom Height.
I started another Topic "3D Adaptive: Lowering Safe Height" if you have any suggestions. https://forums.autodesk.com/t5/fusion-360-manufacture/3d-adaptive-lowering-safe-height/m-p/11794758
