3 axis: Toolpath in Fusion is perfect but machining does not match the part
We have a few programs that we used a couple months ago that ran perfect back then, but when I try to run (repost process) the same program it seems that the machining is over/undercutting all of the parts. I had a feeling it was a fusion update issue, maybe fusion updated but the individual toolpaths did not receive the same update no matter if I regenerate the pathing. For example we bore a lot of holes, we use cutter compensation to let the machines probe tell the program what the tool size actually is. This should cut a perfect hole every time, but they always come out undersized if the program is outside of the recent update time period. We have found a solution that deleting the tool path and recreating the same exact thing tends to fix this issue, would protecting the toolpath be a good solution to prevent this issue and minimize the need for recreating toolpaths?
