I am programming this part on a rotary indexer with a fixture, I have the toolpaths correct how I want them for the most part, but when I post process, the code for the 2D contour doesnt make arc moves, it makes line segment moves. it does the same on the adaptive but that is less of a problem.
Assuming this is a quick fix but I havent had much luck
Perhaps something that needs edited in the post processor?
I have tried a few different post processors and the Haas NGC and the Okuma post processors both do the same thing, but if I post a regular 3 axis part with a similar operation, it posts as a regular expected arc move.
I attached pictures because I cannot attach an .F3Z file type and that is my only export option, I assume because this is an assembly.
