2D Pocket Command Abnormality.
monozukuri.daisuki.higucchan
When an open pocket is selected in the 2D pocket command, the pocket contour is ignored.
Closed pockets seem to be machined properly.
The same happens when a stock contour is specified.
seth.madore
It looks to be an "imported model" issue. If I delete that feature and recreate it in Fusion, I can get a proper toolpath. Holes are omitted for simplicity:
What is the CAD source of this model?
Seth Madore
Thanks, Seth!
However, this data was originally designed in Fusion.
I remember exporting it from Fusion to STEP and then re-importing it.
seth.madore
Ok, that gives us something more to investigate, thanks! Here's a couple of options for working around this issue that this is posing (I apologize if your native language isn't English)
Seth Madore
seth.madore
I did open CAM-61455 to investigate this oddity
Seth Madore
Thanks Seth.
I didn't realize the sketch was recognized as a spline either.
What I find even more interesting is that the drill command works just fine.
You can create a drill operation by selecting either a cylinder or an edge.
Normally the drill command won't let you select geometry unless the hole and tool axis direction match.
fusion2_omni
Community Visitor
Community Visitor
hi monozukuri .daisuki.higucchan hear attached file can solve your problem
