2D Contour = Smooth Toolpath / 2D Chamfer = Segmented Toolpath (Same Model..!)
walrys
walrys
Hi all,
So I was cutting out a part the other day and noticed that my 2D Contour finishing pass was nice and smooth, but the 2D Chamfer tool-path (using the very same model) had become segmented, producing that jerky accel/deccel between points along an arc.  A couple of video examples follow - first clip finishing pass starts at approx 25"
Second clip, chamfer starts at around 28"
Also attaching my project file here.
Original sketch was an inserted .dxf - I know that .dxfs can play a bit weird with F360 - but I'm not sure that's the case here - why would the same arc translate to a smooth tool-path using one strategy and become segmented using another (largely similar) strategy?  Any ideas?
Thanks in advance for your suggestions!
Wal.
seth.madore
The DXF isn't imported as an actual circle, and different toolpaths are able to apply smoothing properly to convert what would be hundreds of line moves into a couple arc commands. It appears that Chamfer lacks the proper Smoothing ability to convert this, which is worthy of a bug report for sure.
As a workaround, you can also use 2D Contour as a chamfer toolpath, although it does lack collision checking against the Shank of the tool. Chamfer (with Smoothing and  points turned on)
2D Contour with points and Smoothing  turned on:
Seth Madore
