2D contour ramp violates geometry with sharp corner
programming2C78B
Advisor Advisor
programming2C78B
ramp roughing with sharp corners enabled:
sharp corners disabled, now lead out goes into model:
proper finish pass:
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
Could you share that file or a sample that reproduces the issue? I made an attempt at it with what I felt would be your settings, but the issue isn't present in this file.
Seth Madore
programming2C78B
Heres a version
seth.madore
Ah, looks like it's going south when Stock to Leave is enabled. Either that or setting Compensation Radius Allowance  to zero will also work
Seth Madore
seth.madore
Do you just have "Keep Sharp Corner" as a default value? It doesn't really do anything for internal closed pockets, so curious what your use case is.
Disregard, I was conflating with the other "Sharp Corner" option for external corners
Seth Madore
seth.madore
I've opened up CAM-58094 to investigate this issue, thanks for reporting it 🙂
Seth Madore
