Message 1 of 10
2D contour issue
06:17 PM
I'm having some weird issues with some very simple 2D contour ops and I can't quite figure out where I'm going wrong. It seems to be when I turn on "in control" compensation.
It's these 4 chamfers here.
If I select one chamfer it works fine.
But when I select all 4 chamfers it adds a little bulge to each one which isn't in the model, and even when I just draw a circle and select that as the contour it does it.
And sometimes when I do it skips one contour and tells me that it can't do it because the given lead would cause a collision. I have compared this op and the other op where it works on all four and it says there is no difference between them.
If I don't add a tip offset it actually joins them together.
