Is there a bug with the new update. 2D contour toolpath all regenerate as an error. See Below
Feature flags: setup-sheet-viewer strategy-blend
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\brian\AppData\Local\Temp\Fusion360CAM\9616-7\operation7.ironjob
Debug: Writing jobfile to C:\Users\brian\AppData\Local\Temp\Fusion360CAM\9616-7\operation7.hsm-job
Debug: Using CAM kernel from: C:\Users\brian\AppData\Local\Autodesk\webdeploy\production\1a27f23c10bc87f7eab1f89e440a46f886b5f544\Applications\CAM360\camkernel.exe
Error: Internal CAM kernel error. Please report through your support channel.
Debug: Autodesk dcamcomponents 1.111.1 pm12704
Autodesk CAM Kernel 3.41.3 (3b52178d) x64 STABLE vs2017 3b52178d23971b9c474c3ce2c275265e938c8c24 2021/11/15 03:00
Traceback (most recent call last):
File "operation7.ironjob", line 123, in <module>
job.run()
File "lib\hsmkernel\Operations.py", line 192, in run
File "operation7.ironjob", line 69, in onRun
op1.setParameter('roughingSmoothingDeviation', ) # smoothingDeviation
TypeError: setParameter() missing 1 required positional argument: 'value'
Debug: Total processing time: 93 ms
Debug: Total elapsed time: 160 ms
Invalidated: Generation failed
