2d bore issue on finishing pass
12:43 PM
I am milling a pocket that has a diameter of 8.76mm, using a 6mm single flute end mill. I am using the "Bore" feature. When I have the checkbox for "finish pass" checked, the end mill will gauge the part on the finish pass, as it tries to lead in outside the diameter of the hole. There is no way to control that lead in, or to prevent that from happening. My work around was to not run a finish pass, but I believe there is an issue with that feature in regards to leading in on the finish pass only. If I am neglecting a setting or if I am missing something, please advise.
Thank you.
