2d and 3d adaptive violating optimal load on lead in.
hello.
Today i noticed something different when machining something i have machined many times over the past year. It is a basic block with a extruded circle on top of it. I created a new model, used my normal cam method (3d adaptive), popped it the machine, hit run and ......... no good. what i have found is the lead in violates the optimal load by about 1mm. which for me is a big deal as my machine is not capable of taking 1.7mm width of cut at 5mm doc. I have uploaded a screencast of my problem. If i choose a entry point it adjusts the tool path and enters from the side which is a work around for now but should not be necessary.
If anyone can help or shed light on this that would be great. It seems to have only happen in one of the latest updates.
thank you.
