Drop down available for Item Filter
If you want to find some specific Items, you can go to the Item Descriptor (as example) and with different types of filters, you can edit conditions for the filter. Firstli, you define the behaviour and then as a free text, the search condition.
 However, if you put a typing error, it has a direct impact on the search results. A helpful and easy way would be to have a drop down list, filled from the data. As is in Excel, that is a smart and easy filter for quick filter results. 
Filter_2.pngIn Excel you can use for filtering data as drop down, or you have the posability in a search field, to put text as a plain text. All that does not match, will be filtered out.
Then you can confirm it. As soon as it is confirmed, you get a filtered list.
A similar behaviour would be a great improvement. It would enhance the usability from F360M
Filters are very often used and in every Workspace it is different. Type of search results are always different.
When the user is guided, this helps to increase the usability and reduces frustration.
