Display full path to workspace on main screen
It will be usefull if user can see where is actual workspace. Display path to workspace will be a solution. You can have in Fusion Manage more than one same named workspace, so only the name is not enought.
2 Comments
philipfrench
OR... swap position of the "+" button and "Home>Projects" location, and make MORE ROOM for the workspace name, so it does not get truncated.
(Name does not have to be unique, you are correct. But it is common sense to do so. When you Import, or create a Report, you are selecting from list of workspaces. If you have workspaces with same name, then you do not know what you are selecting!?)
bruce.nyfeler
This is still open and not improved. A small change would make a big difference.
I can't understand why nothing is being done about it.
