In the General Settings, you can define a default date format, but this is a free text field. I would recommend that the system then has a dropdown instead of a free text field. The format is based on a coding language, and not on a user. Not all system admins are code-savvy to know the entry should be MM/dd/yyyy and not mm/dd/yyyy or MM/DD/YYYY.
Also, the system should only display working date formats to avoid confusion. Currently the dd/mm/yyyy date format is not working as expected.
