Audit history for Workflow is not getting reported correctly in Setup log
HI,
I would love to see a version control mechanism for  workflow in future releases.
Also when ever there is change made to the Workflow transitions or new TASK is added , that change does not get recorded in the set up log.
It records the incident as Workflow editor - NO CHANGES MADE, which is not correct.
So I would love to see the audit history of any changes made to the workflow in the setup log.
pnigam
2 Comments
nguyentru
Status changed to: Accepted
Hi Pnigam,
I appreciate you have taken the time to write and share with us regarding the Setup Log not prperly display worflow update.
I already have created a ticket and have raised awarness to the PM team and Dev team.
Thank you,
Trung
benderk
Status changed to: Archived
Hello -
As noted in the forum post https://forums.autodesk.com/t5/fusion-lifecycle-forum/setup-logs/td-p/5802788, this issue has been logged as a bug to investigate.
Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
