Advanced Print Tool to Improve
This ADV part is not convenient and should be improve to ease creating really customizable reports and is not enough powerful to provide necessary options. In this part we can have 2 sub functions:
The standard Editor:
  • It is not easy to insert a picture on the top / bottom, we are obliged to use existing picture from url instead of defining somewhere the pictures to used and then refer to one of them.
  • It is not possible to define customized tables as embedded ones and in the same time sometimes we are obliged to use the embedded because they are automatically adapted depending of the content (e.g BOM).
  • Inserting the fields is likely we are inserting a code, (e.g. ${workflowAction["step"].value}). We should have something like an "object".
  • No possibility to hide/show special tables.
  • We should have an interface more customizable by the mouse, to be able to move easily the elements without selecting it and used copy / paste.
The Source Code Editor:
  • This is not a real editor but if we need to be able to have more possibility of customization there is no choice than copying/pasting this code outside of the editor (e.g. with VS Code),
  • The code is not indented,
  • There is no autocompletion,
  • The header tables are defined with predifined unknowned styles,
  • This is not possible to define our own styles, we shall go on each HTML tag to define colors, the borders, etc...
  • No possibility to hide/show special tables,
  • No possibility of scripting,
  • This is like we are using HTML code like in 1995 with HTML 2.....
In addition, whem using it with the BOM, the related items fields cannot be used in the ADV, so this ADV is not usable for that case.
This is likely this part has not being updated since a very long time or probably when the formal Fusion 360 tool has been released.
If some users know the limitations of the tool, it will be weclome to anwser to this request/idea.
