Set Lifecycle State and Revision via API
ForrestJudd
ForrestJudd
I am trying to bulk-load Items into a Revision Controlled workspace. I have no problem creating the items, populating fields, adding attachments, etc.
However, I need to mark the records as 'released' with their current revision value. This means I need to specify a Lifecycle State and Revision for the Items at some point. Can this be done to the Items directly via either the v1 or v3 API?
I could certainly add the Items to a Revisioning record and manipulate that record's workflow, but doing that for thousands of part numbers in a short period of time sounds like a good way to run into server performance limitations or timeouts.
I saw this forum post with a reference to using a PUT to a v1 endpoint on the item specifying a URI like so:
[workspace]/[itemid]/lifecycles/transitions/[lifecycletransitionid]
And passing an XML body specifying the revision value, but that didn't work for me. And that also doesn't allow setting an effectivity and release date. I don't need to set any specific dates for effectivity, though, I just need to get these Items into a 'released' state with the correct revision.
tony.mandatori
I've used this API before. There is no equivalent in v3 that I know of.
tony.mandatori
The Content-Type should be application/xml
And the payload should look like this:
<dmsVersionItem>
<release>
A
</release>
</dmsVersionItem>
URL should be something like this
/api/rest/v1/workspaces/57/items/9153/lifecycles/transitions/14
Where the transitionID is obtained from
/api/rest/v1/workspaces/{id:[0-9]*}/items/{dmsID:[0-9]*}/lifecycles/transitions
ForrestJudd
This worked perfectly, thanks!
