Report API Dynamic filter inputs
viral.shingala
viral.shingala
Community Visitor
Community Visitor
Hi f360-manage-support,
We are leveraging Reports API  (https://axonprd.autodeskplm360.net/api/rest/v1/reports/212239), Looking to pass dynamic filter values in the GET Report API.
Can you please guide how I can pass dynamic filter values in the API?
cc @Anonymous @Anonymous
philipfrench
Sorry, I do not think the API supports the passing of dynamic values.
(I hope someone can correct me)
When you do this in the UI, it is running a request similar to below, so you might be able to do this using a report embedded in a computed field in an item details page, however the authentication you do when using APIs does not work for these links, because they are not API calls.
You might have to replace your code with the search API, either v1 or v3 (they both have pros/cons).
https://XXXX.autodeskplm360.net/reportRunAjaxRequestorAction.do?reportID=6671961&workspaceID=68&repo...
