Reference Classifications From Workspace
I'm setting up a workspace that auto-creates a description for a new item based on the fields associated with that item in the classification manager. This workspace will hold a number of records that would be indexed in this method: '430 - Resistor', '440 - Capacitor' such that it is easy to quickly identify each record and modify it if needed.
Currently, I would have to manually input both '430' and 'Resistor' in the workspace and ensure that I've got the correct item code and classification with respect to what has been defined in the classification manager, which is possible. Although I'd much rather enter the item code and have the classification derived from the code, or even better yet, select the classification through the classification tree to ensure there is an error-proof reference. But I can't do this because most of my classification fields are defined as required to ensure that all fields are entered and the proper description is created. Is there anyway to reference the classifications from this reference workspace without needing to populate these fields or even just hide them? All I would need is the name of the classification and the item code associated just as a selectable read-only reference.
John Biskey
