Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Pick list generation errors
5 REPLIES 5
606 Views, 5 Replies
I seem to be having problems with work-space linked pick lists generating on user forms. It seems to be inconsistent. Sometimes it works sometimes it doesn't. Are there some performce issues today?
David.
5 REPLIES 5
Hi David,
I just did a quick check and I’m not seeing issues on our end or anyone else reporting problems with the pick list.
What kind of behaviors are you experiencing?
Hi. See the attached images that show problems with a drop-down list config. It also doesn't seem to work with a search type either. I havew tried this on several web clients and it is the same on all.
David
The error seems to be repeatable at my end;
1) Create a form that uses a WS linked pick-list, single selection
2) Check from, create some items, works OK
3) Change field setup to be a search type rather than single selection
4) Try to create another item - search field does not display in form.
5) Check field setup back to single selection
6) Try to create a new item - drop down list generates
David.
Hi David,
I just followed your instructions and I was unable to reproduce this in Chrome or I.E.
However I might be missing something are you doing this with multi browsers, as in one for front end test and one for back in? Or multi tabs or single tab?
I'm primarily using Firefox but I can replicate it in IE and Chrome.
I'm using one browser session with multiple tabs.
