Javascript require() method
Message 1 of 10
hi experts
i'm trying to make an HTTPS call from Fusion to my AWS server.  The call involves:
var https = require()
but this method is not recognized by Fusion.
Further searching, require() method is a part of requirejs which has to be installed in node.js.
in short, have you tried calling out to HTTPS from Fusion script ?  and how to do it?
thanks
KP
Replies (9)
Message 2 of 10
tony.mandatori
I have used require() before in node.js to load other code code and libraries (like log4js and fs).
There is a port for client side loading of files.  But the javascript in Fusion is server side only.
require() is not part of standard JavaScript, it is built into Node.js to load modules.
Message 3 of 10
tony.mandatori
You should be able to make HTTPS requests using the same method we use for the Octopart integration.
        var xhr = new XMLHttpRequest();
        xhr.open('GET', url);
        xhr.setRequestHeader('Content-Type', 'application/json');
        xhr.setRequestHeader('Accept', 'application/json');
        xhr.send();
i haven't tried this.  Let us know if it works.
Message 4 of 10
thanks Tony
I have tried var xhr = new XMLHttpRequest(); before posting here.  It's only good for http web call.  My web server is ssl enabled
Message 5 of 10
tony.mandatori
From what I see online, it should work with HTTPS as well.
Again, I haven't tried this.
Message 6 of 10
Depending on your authentication method you may be able to set additional
request headers in this manner
xhr.setRequestHeader("Authorization","Basic XXXXXX1XXXXX2XXXXX3XXXXX6==");
The "XXXXX" is the base 64 encoded authorization credentials.
Michael Pares
Message 7 of 10
tony.mandatori
Just be careful because the Base64 encoding is not encrypting... so people can get the password from the string.
Message 8 of 10
You are right.  It can be decoded just as easily as it is encoded.
Message 9 of 10
i have an self signed certificate on the server. this kind of cert always prompt user to trust it in the browser and in code.  how do you ignore its warning in the script
Message 10 of 10
I did a little search and find that a lot of people have asked that question before and come up short when it comes to javascript.
http://stackoverflow.com/questions/4490723/javascript-xmlhttprequest-ignore-invalid-ssl-certificate
Most suggest that you need a valid cert.
