Hello everyone,
is it an expected behavior in PLM that when an item is created via scripting ( createItem("WS_XYZ") ) fields with default or required values stay empty?
For example if you have a field with priority LOW/MED/HIGH and you set the default to MED, the field will have an empty value when it is created from a script.
Also when you set up a field to be required, creating a record via script will not give a warning or error, that there are missing values.
Right, now you need very deep knowledge of the workspace configuration, to avoid this in scripting.
