Issues with updates and the modern interface?
ThomasRambach
Advisor Advisor
Message 1 of 11
ThomasRambach
Anyone else seeing issues using the modern interface now that updates have been rolled out? What worked previously is now not. Can't create items in one workspace, can't see a picklist in another. The timing seems right on with the April 1 update and todays update. I have 2 tickets with Autodesk pending now.
Replies (10)
Message 2 of 11
john.denner
I'm having issues saving new views. If I navigate away from the page it deletes it. I also can't add columns to other views.
Message 3 of 11
giliar.defriesperez
Just a quick update: the development team is actively working on this. More news will come through the support cases, but I wanted to give you an update so you knew we are aware of this problem.
Giliar de Fries Perez
Sr. Product Owner
Fusion 360® Manage
Autodesk Canada Co.
Message 4 of 11
ThomasRambach
Thanks for the update. I would appreciate a discussion with Autodesk regarding this after the fixes are in place.
Message 5 of 11
Having the same issue with picklists not being editable since the update.  They can be entered upon the creation phase but if returning to select editable picklist later, it's not showing up as editable.
Message 6 of 11
giliar.defriesperez
Hi @Anonymous, others,
We're working hard on fixing this issue. The fix is being validated internally already, and it's looking good. Please make sure to file support cases so you can get timely updates on the issue via the formal channels. I'll have an ETA for this fix to be released soon.
Sr. Product Owner
Fusion 360® Manage
Autodesk Canada Co.
Message 7 of 11
rnoriega
Thank you for the update.
Message 8 of 11
giliar.defriesperez
Hi all,
The fix for this issue has been released to Production. We fixed a few other issues and added some other improvements - check out the release notes.
If you observe any other issues, please make sure to file a support case.
Giliar Perez
Product Owner - Fusion Lifecycle
Autodesk Canada Co.
Sr. Product Owner
Fusion 360® Manage
Autodesk Canada Co.
Message 9 of 11
rnoriega
I took a quick look and yes it does look fixed! I'll let you know if I see any issues.
Thank you for the update!
Rick Noriega
Message 10 of 11
ThomasRambach
Thank you @giliar.defriesperez. Excellent work by Autodesk of tackling this issue.
Message 11 of 11
Thank you! Resolved our issue.
