Help with Managed/Linked Items
We have two workspaces, "Supplier" and "Supplier Enquiries".
I'm trying to script from the "supplier enquiries" workspace, to add itself as a managed item in the "Supplier" workspace.
For testing I've set up an on-demand script, that is as such:
        item.SUPPLIER.workflowItems.addItem({RELATED:item, SUBJECT:item.SUBJECT, DATE_RAISED:item.DATE_RAISED, INFORMATION: item.QUOTE_RECEIVED_AFTER});
It's creating the linked item, however I can't get it to copy over any of the custom fields (subject, date raised and information).
item.SUPPLIER is a linked field to the supplier workspace.
Pulling my hair out here, what am I doing wrong? Any help would be greatly appreciated.
Cheers,
Stuart
tony.mandatori
I tested this and I was able to reproduce the issue.
I was able to workaround this by structuring the code as follows:
var workflowItem = item.RELATED_ECO.workflowItems.addItem({RELATED:item});
workflowItem.ITEM_SUBJECT = item.NUMBER;
Can you try this and see if it works?
Can't say I understand what's going on with the original code, but what you suggested has worked a treat!
Cheers
var thisIsAVariable = item.SUPPLIER.workflowItems.addItem({RELATED:item});
        thisIsAVariable.SUBJECT = item.SUBJECT;
