Add new item revison in revisioning workspace using API
david.siegert63GB8
Message 1 of 1
david.siegert63GB8
is there a way to add new revision in revision controlled workspace? Is updating the working revision and adding new revision controlling Change Order item the only way?
Using import for ex. form Excell allows to import new revision without creating change order. But only works with lifecycle, revision and release date filled. Is there some endpoint in API doing something similar?
What I am trying to do is import changes and new items from Vault to F3M. As I understand it now if I want to change from revision A to C I need to create 2 change order and go through the release process twice.
Thank you,
David
Replies (0)
