In our FLC system, Existing relationships on Materials and Specifications are carried over as one way cross references to the new working versions. Changing these relationships to bi-directional relationships by manually recreating the link is usually fine, but when dealing with specification that have hundreds of relationships it can very quickly become a serious headache and currently there is no simple way to switch between the cross reference types.
What I would like to see is that the type of cross reference added to the 'Type of Relationship' drop down list in the edit screen in the Relationships tab, which currently only shows 'Cross Reference' in the list regardless of whether it is a one way or bi-directional reference. While not a perfect solution it would be far more efficient that manually punching in or copy pasting the material/spec numbers.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
