we should be able to make information in a pick list selectable or non-selectable by an on/off button next to each picklist item. Currently to make information non-selectable from a pick list we have to remove the record/ delete it...
for example: we have a pick list in our Change Order Workspace that tells us what type of change it is- lets say a Picklist called "Change Type" with selectable options of...
1.)Document update
2.) Initial Release
3.) Design Change.
lets say I don't want "document update" to be selectable anymore. the only way to make it non-selectable is to delete it. that causes all the completed change orders that had "document update" selected to be blank now. (BIG PROBLEM)
this will cause problems for our auditors. we should be able to turn on and off selections from a pick list but keep them active so they don't get removed from old change order records. basically just make them not selectable from now on but still active.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
