As you aware it's quite cumbersome to navigate b/w the scripts in FLC. Updating the scripting interaface to easily navigate b/w the scripts would be a cool feature which makes the implementer job easy.
For example, if an action script imports multiple library scripts, it would be difficult identify the correct library for a given function unless proper naming convention is used across the board.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
