It seems very odd that the Numbering sequence in a BOM doesn't update when you remove and Item from the BOM.
for example: BOM 123 has three items,
(1.1) X
(1.2) Y
(1.3) Z.
if you removed Item Y and added Item A the BOM would look like this...
(1.1) X
(1.3) Y
(1.4) A
the New Rev would skip 1.2
It seems like it would be better if the Whole BOMs item Sequence were re-numbered. its just confusing when you look at a BOM that had multiple Changes to it and its all out of sequence.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
