We frequently make use of a closed loop transition in combination with the escalation function to create a scheduler. Very often, we run this once per day which soon clutters up the workflow history making searching for more valid transitions difficult. In the example below you can see the transition called Scheduler has run in succession for 4 days. They can in reality run for much longer than this which just clutters the workflow history with irrelevant information.
What would be ideal would be ability for admin to suppress certain transitions from the workflow history. There still has the be a way of ensuring the scheduler is still running so perhaps allow admin only to see these transitions but suppress from the normal user? Alternatively, allow the user to filter the transitions that they want to see at the top of the workflow history.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
