Hi guys,
All I want to try is write to the comments in the sourcing tab via scripting. The scripting reference shows it's read-write.
I currently have 1 supplier in my sourcing tab so in an on Edit script, I use....
item.sourcing[0].comment = "this is a test comment";
It doesn't appear to be working after I edit and save the record. I go back to the sourcing tab and it shows blank still. Wondering what's the correct way to do this?
correcdtg
Syntax looks good {confirmed in Help: item.sourcing[i].comment (string) User-provided comment on the specified Sourcing entry in the array (read-write)}
A case has been created ( number 12514782 for your reference) so we can dig in deeper.
Michelle
Any updates on the status of this?
I'm seeing a similar issue when trying to update an existing Supplier or Quotes on a workspace.
Creating them when none exist works fine, just not updating...
It is not possible at this time and so I have scrapped this portion of my design and opted to create fields in the front of the record where I have scripting access to.
