I'm working on a workspace where I have a checklist the user will have to go through, it consists o a text field and some check boxes.
Next to this row of fields, i would like to have another row of fields that shows a red or green color, depending if text is filled in to the text box, or the green if the checkbox is checked of.
I'm using a computed field for this, when the value of the field is NULL the field will go red, and when something is filled in green.
I works perfectly for a text field but not for a check box? So my question is, what is the value of a check box when it's not checked??
Hope someone can help..
Best regards from Denmark.
Kasper
Solved by Kasper_Arvad. Go to Solution.
Found the solution myself - it's late in the day apparently...
The value is of course: FALSE
