Hi guys,
I get a time out error when the transistion runs my action script. This is the first time I'm seeing this and the only thing different about this record is the large number of attachments. There are 33 files attached to this record where I'm taking each attachment and creating a hyperlink for each. Ususally the file attachment sizes are under 10 but this was an exception.
When I try the same script with say 1 file, it is able to run. What options can I look into?
2016-05-31 16:34:31.166 | Jason Leung (leungjcp) | [ECO_Notify_complete (line 136, col 0)] org.mozilla.javascript.WrappedException: Wrapped com.dms.scripting.exceptions.ScriptTimeLimitException: Script ran too long: 10733ms (ECO_Notify_complete#136) |
Solved by leungjcp. Go to Solution.
This seems to be the offending code.
for (k = 0; k < arraylength; k++)
filename[k] = item.attachments[k].fileName;
fileid[k] = item.attachments[k].fileID;
drawing_links[k] = '<html><body><br><div style="text-align: left; padding-left: 200px"><font size="2" face="Verdana, Arial, Helvetica, sans-serif">'
+ '<a href="https://nucap.autodeskplm360.net/servlets/DownloadFile/'
+ filename[k] + '?fileID=' + fileid[k] + '&dmsID=' + dmsID + '&workspaceID=94">Updated Drawing: ' + filename[k] + '</a></font></br></body></html>';
format_link[k] = '<br><a href="https://nucap.autodeskplm360.net/servlets/DownloadFile/'
+ filename[k] + '?fileID=' + fileid[k] + '&dmsID=' + dmsID + '&workspaceID=94">' + filename[k] + '</a>';
When I remove this portion of the code it works fine. Even if I leave the first line in the for loop, it times out. All I'm trying to do is get the hyperlinks to the attached files....and put them in another work space for others to see. See image.
Hi Martin,
I initially, during development, thought about using the above mentioned method but we utilize reports heavily to see pending tasks. When Engineering finishes their work, the result are part drawings and multiple records are then created for specific departments to monitor their progress. In each new record, I write to a field all the hyperlinks for the attachments.
Each department point person can now view and have easy access to the drawings through a link in their report. Here's a sample image.
Bastien helped me today to resolve this issue for now. My script was timing out at around 22 attached pdfs. We removed "getprintview" line of code which I was not using and it gave me 1 extra pdf for a total of 23 before time out. For us....it may be an on-going issue.
Doesnt look like this was metioned,
Another solution you can look into is reducding the over all scirpt and inculding 3 functions,
1. to collect to given information,
2. create the hyperlink
3. to populate the given information to target workspace.
This will extened the amount of time you have to run the script overall, provided you with flexibilty on changing the script or adding changes, and you might find it to actual run faster
~Joe P
Yes,
So it would be something like this:
Action script to find the item > pass item and target location to first library
>library script to create the hyperlink > pass hyperlink and target location to second library
>>library script to add to workspace > write information to target item
The values you would pass would be
item in question
link to target workspace
Whoa...so I created a library and I input item.attachments to it. From there I do all my looping. The output is a list of hyperlinks.
The computation is much faster now. Visibily the spinning wheel finishes faster. I was only able to attach roughly 22 pdfs before. Now I am able to attach at least 43 pdfs just by placing my loop in a library script.
Thanks all.
