Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
REST API PUT Item with Mutiselect
2 REPLIES 2
kkurkowskiRSKB7
600 Views, 2 Replies
I am attempting to update metadata fields on an item using the REST API.  I am able to update metadata fields but any selections in multiselect fields are lost.
The example for "PUT: Replace workspace item" (http://help.autodesk.com/view/PLM/ENU/?guid=GUID-DCA5139F-6881-44D0-9699-0E9C834C2F2B)  shows key/value pairs for fields.  This works fine for various types including single select pick lists but I how do I send in multiple values for a multiselect field.
The GET returns a "selections" property in FieldData. How do I maintain what was already selected in the multiselect.  Can the value in the key/value pair be an array of objects? I don't see a "selections" property on the field data in the PUT.
2 REPLIES 2
When you post to an item that has a Multi-Select Linked Picklist (Referencing another workspace) or a picklist of Values, the "value" needs to be a comma separated list of ID's (DMSID for Linked Picklists).
Also keep in  mind that  you need to pass in all fields on a workspace or it will assume you're entering a null value.
    "versionID":0,
    "metaFields":{
        "entry": [
            {"key": "INSPECTION_TYPE", "value": "5"},
            {"key": "INSPECTED_BY", "value": "1"},
            {"key": "INSPECTED_ITEM", "value": "249"},
            {"key": "SOME_LINKED_PICKLIST", "value": "1234,1235,1236"}
Sailin Benedum
D3 Technologies - Solution Consultant
D3 Technologies | Connect with me on LinkedIn
Thanks Sailin.  That did it.  Perhaps Autodesk will update the documentation to include a CSV string.
