I would like to know if it is possible to modify the HTML code of the different windows:
- when you want to add an 'additional owner' on an item, a popup windows appears. I want to modify its size
- when you want to add an affected item in a Change Order (Revisioning Workspace) a popup windows appears. I want to modify its size, the information (add a column),....
Thank you,
Sylvain
Solved by gasevsm. Go to Solution.
the change additional owner window is already a resize-able window, the default size is 800x600 but you can resize it after it's shown. if you want to modify the default size, you may need to use some browser extension to override the script. similar to the size of add affected item dialog, you may use an extension named "stylish" to change the size.
If you want to add a column to the dialog, that will be very diffcult at client side. what kind of field(column) you want to add? if you just want to add an itemDetails field, you can consider add that field as part of the Descriptor.
