I have many fields that are multi picklists and I am trying to import to them but can not find how to do this. I can import to a single picklist easily but how should the selections be formatted in excel for import when I need multiple answers selected?
Denise.
Solved by porkodi_autodesk. Go to Solution.
Hi Martin,
Thank you for the help, although I seem to still be having trouble, it does not accept what I have in the import tool. See attached screen shots of the picklist in the system and what I have in the import tool.
Appreciate any further assistance you can give.
Denise.
Hi Denise,
If you want the options Aerosol and Nonflamable as separate values in the multiple selection picklist, try separating the values with comma in a single cell in the import file .
If you want the values Aerosol,Nonflamable to appear as a single option in the picklist ,try using Aerosol\,Nonflamable in a single cell in the import file .
Thank you !
Porkodi Nathan
