Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
How to filter a GET request of Workspace Items
12 REPLIES 12
Message 1 of 13
bgriffinEVHGY
679 Views, 12 Replies
I am trying to get a large list of workspace items and want to cut down my runtime. Currently my implementation creates a navigator on my project space, performs a GET request for a page of records, iterates through all the records on the page, and adds them to a ProjectList object one by one. This list is then displayed by a form. Ideally, I would like to be able to filter results before performing all the GET requests so I don't fetch records I don't need. Is there a quick way to filter out some records by their attributes before I GET them?
12 REPLIES 12
Message 2 of 13
shenx
in reply to: bgriffinEVHGY
two APIs you can use, both can filter results.
/api/rest/v1/reports/{reportid}   -- you need to define the report to fit your needs
/api/rest/v1/workspaces/{workspaceId}/views/{viewId}   -- define the workspace view for the workspace
Message 3 of 13
rsbishop
in reply to: shenx
Can I create a report that requests a value on runtime and populate that value when I do the API call?
Message 4 of 13
shenx
in reply to: rsbishop
you may not call report object directly in script, but as reports are actually http calls, you may consider change the report call in your script and use it.
e.g. one of my report has URL
/reportRunAjaxRequestorAction.do?reportID=1709&workspaceID=21&reportTypeInRequest=reportTypeHtml&index(1__NEWROW)=&value(1__ALL_FILTER_FIELDS__NEWROW)=NAME_FILTER_META_DMS_TYPE_4&value(1__ALL_FILTER__NEWROW)=2&value(1__FILTER_VALUE__NEWROW)=mynewfiltervalue
I can change the filter value in the script to get a new report content.
Message 5 of 13
rsbishop
in reply to: shenx
Great, thanks for the info.  I'll see if I can adapt this to C#.
Message 6 of 13
johnny.buccola
You can also use the SEARCH endpoint:
POST api/rest/v1/workspaces/{id}/items/search
This returns a list of items in a workspace, pre-sorted and/or pre-filtered on as many fieldIds as you'd like to include.
It's a little tricky to use (read the documentation closely), but is much quicker than filtering the data after you've received it all in a GET request.
I have some examples in Python if you're interested.
Message 7 of 13
I was looking through the documentation on the search and came across the part about the searchDefinition. I couldn't find an import for this, is this an object I should create or is there an import for it somewhere?
Message 8 of 13
Once I have done the POST request how do I get the items that are left after the filtering?
Message 9 of 13
Please ignore previous replies. I have figured out most everything, but I am having trouble making the objects for the search request. I have been using postman to debug my post requests and even when copying the example request exactly and changing values to match my schema, I'm still getting a 400:Bad Request response from the server. Just wanted to see if anyone had any feedback about what might be missing here?
    "pageNo":1,
    "pageSize":10,
    "logicClause":"OR",
    "fields": [
            "fieldID":"NUMBER",
            "fieldTypeID":9
            "fieldID":"TEST",
            "fieldTypeID":4
            "fieldID":"TEST_NUMBER",
            "fieldTypeID" : 20
            "fieldID":"DATE",
            "fieldTypeID":3
    "sort" : [
            "fieldID":"TEST",
            "fieldTypeID":4
            "sortDescending":false
    "filter" : [
            "fieldID":"TEST",
            "fieldTypeID":4,
            "filterType" : { "filterID" : 4 },
            "filterValue":"Please work"
Response is:
HTTP Status 400 - Bad Request
I have also tried removing the filter section and get the same response.
Message 10 of 13
rsbishop
You really weren't kidding when you said read the doc carefully.
fieldTypeID refers to which tab you're looking for the field in.  In our case, it was in item details (fieldTypeID = 0)  Outlined here: http://help.autodesk.com/view/PLM/ENU/?guid=GUID-10176FF2-6DFB-4487-B98C-64637B607894
"filterType" : { "filterID" : 2 },   is referring to what type of search.  2 meaning "contains".  Outlined here: http://help.autodesk.com/view/PLM/ENU/?guid=GUID-74B74433-47FC-4654-8569-607DBEEDD95E
Thanks everyone for the help.  Give me 10 minutes and I'll run into another problem Smiley LOL
Message 11 of 13
rsbishop
Just so the next person doesn't have to decode the documentation, I'll share my C# class for searchDefinition as well as an example of its use.
Here's the class:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Newtonsoft.Json; //not really required, but useful
namespace YOUR_NAMESPACE
    public enum Operator
        Contains = 2,
        StartsWith = 3,
        EndsWith = 4,
        DoesNotContain = 15,
        IsBlank = 20,
        NotBlank = 21,
        Is = 15
    public enum Tab
        Undefined = -1,
        ItemDetails = 0,
        Workflow = 1,
        GridView = 2,
        LogInfo = 3,
        Attachment = 4,
        Linked = 5,
        BOM = 6,
        WhereUsed = 7,
        Relationship = 8,
        Sourcing = 9,
        Lifecycle = 10,
        WorkflowHistory = 11,
        Milestones = 12,
        BOM_Secure = 13,
        Associated_WF = 14,
        Descriptor = 15,
        AllFields = 99
    class searchDefinition
        public int pageNo { get; set; }
        public int pageSize { get; set; }
        public String logicClause { get; set; }
        //Fields
        public List<fieldsItems> fields { get; set; }
        public class fieldsItems
            public String fieldID { get; set; }
            public int fieldTypeID { get; set; }
        //Sort
        public List<sortItems> sort { get; set; }
        public class sortItems
            public bool sortDescending { get; set; }
        //Filter
        public List<filterItems> filter { get; set; }
        public class filterItems
            public filterTypeItems filterType { get; set; }
            public class filterTypeItems
                public int filterID { get; set; }
            public String filterValue { get; set; }
        public String toJson()
            return (JsonConvert.SerializeObject(this)); //again, not required, but useful
Here's the implementation:
searchDefinition def = new searchDefinition
                pageNo = 1,
                pageSize = 10,
                logicClause = "AND",
                fields = new List<searchDefinition.fieldsItems>
                   new searchDefinition.fieldsItems
                       fieldID = "NUMBER",
                       fieldTypeID = (int)Tab.ItemDetails
                sort = new List<searchDefinition.sortItems>
                    new searchDefinition.sortItems
                        fieldID = "NUMBER",
                        fieldTypeID = (int)Tab.ItemDetails,
                        sortDescending = false
                filter = new List<searchDefinition.filterItems>
                    new searchDefinition.filterItems
                        fieldID = "TEST",
                        filterType = new searchDefinition.filterItems.filterTypeItems
                                filterID = (int)Operator.Contains
                        filterValue = "hello world"
Pretty much just populate a searchDefinition object, serialize it, and stick it in the request body.  Hopefully someone finds this useful. Cheers
Message 12 of 13
johnny.buccola
Sorry for going completely dark there... sounds like you handled it!
As you clearly discovered, the kicker is just understanding WHERE in the documentation to find each of the required ID values. Both fieldTypeId and filterType are static (unless you modify them in your tenant, of course), so if your filter is going to be the same every time, you can hard code them into your request template.
Since you seemed to have nailed it, I'll just provide another JSON object example for fun.
This is used for searching a given part number, and returning any matching items with the fields Number, Description, Lifecycle Name, and Release Letter. Because the filter 'Latest Release' is set to 'Yes', this ought to only return a single value, assuming 'NUMBER' is an exact match.
search_term = "6-07454-01"
request_body = { "logicClause":"AND", "fields": [ { "fieldID":"NUMBER", "fieldTypeID":0 }, { "fieldID":"DESCRIPTION", "fieldTypeID":0 }, { "fieldID":"LIFECYCLE_NAME", "fieldTypeID":10 }, { "fieldID":"LC_RELEASE_LETTER", "fieldTypeID":10 }, ], "sort": [ { "fieldID":"NUMBER", "fieldTypeID":0, } ], "filter": [ { "fieldID":"NUMBER", "fieldTypeID":0, "filterType":{"filterID":15}, "filterValue":search_term #value to 'search' on }, { "fieldID":"LATEST_RELEASE", "fieldTypeID":10, "filterType":{"filterID":13}, "filterValue":"Yes" } ] }
Message 13 of 13
rsbishop
in reply to: johnny.buccola
Awesome.  I'll probably end up creating some controller classes that will create the filtered request as well as deserialize the result.  They'll have to be specific to the workspace, so I'll end up with a bunch of these controllers.  I appreciate all of the help.
