We have been using Fusion Lifecycle and I see when I attach files I can select files from my Fusion Team. Do you know if there is scripting access from Fusion Lifecycle to Fusion Team.
For example after a workflow transition I want to upload a pre-determined file into my attachments tab from Fusion Team. Would I be able to do something like that. (search for file and if exists, upload file)
Solved by gasevsm. Go to Solution.
Hi Jason,
We are in the process of upgrading the scripting engine to the new Attachments and Fusion Team integration.
If you have any good ideas on the functions you would like in it, I strongly suggest you create a post on the idea station so your fellow community members can vote on it.
Looking forward to see what you have in mind...
