When I import a BOM in Fusion Lifecycle, I have a small issue. In my excel file, I have a column called "Quantity" and when I would like to use this file in FLC, I am obliged to map manually this field to the "Quantity" property (in the import tool).
For 'basics' properties, if they have the same name, FLC finds and maps automatically the fields but not for the "Quantity" field. Is it possible to do it?
I try many things but for me it is impossible because "Quantity" is a "BOM field" and not an "Item field". Is that true?
Thank,
Sylvain
Solved by porkodi_autodesk. Go to Solution.
Hi ,
It is true that "Quantity" is a "BOM field" and not an "Item field".That is the reason we have to map the column manually to the quantity property of the import tool .
Thank you !
Porkodi Nathan
