Hi guys,
Wondering if there is a bom difference feature. I can't remember if there is or not. I'm using a level bom.
Here's an example. I have 2 top level bom, "JASON" and "JASON V1". The sub-level BOM is "Family" and "Family V1". The last level are the members in the family. Assuming there is a bom diff feature, will it output the difference in family members? In this case N,J,Q and D,K,V?
Solved by gasevsm. Go to Solution.
To add a little to what Martin indicated,
The differencing function allows you to specify different effectivity specifications such that different versions will be selected all the way down the bom - it's based on Effectivity and version of the parent.
