part number issues
Basic summary is that fusions already barbaric workflow for adding dimensions to parts list has now been doubled or tripled with the addition of the part number feature. Getting dimensions to appear in the parts list of a drawing requires extensive manual entry and can lead to potentially huge errors for a small over sight such as forgetting to manually update the description of a part which has had it's dimensions changed. This work flow is just silly to begin with, but now in addition to opening the properties of every single component for adding dimensions you also have to "remove from shared part number". I thoroughly do not understand fusions goal here, a task which I would describe as bare minimum, fundamental to any CAD software is the ability to create the model, then the drawings, then a parts list, this should be straightforward, easy, and at this point automatic yet it is the exact opposite. It requires huge amounts of time consuming, annoying, and repetitive work all of which can be wasted if the drawings get changed or updated after the fact - now new features are coming in which make this terrible workflow even more cumbersome - someone from fusion please ELIF what the purpose of this is and why it hasn't been fixed yet?
