No make editable menu in data panel. Reached 10 document limit.
jackson.campbellE85N9
I can't change documents from editable to read only to make room for new designs under the 10 active document limit.  There is no drop down menu to change the status.  I also don't see any document tracker with a "0 of 10" or any other number.
brian.mark
@jackson.campbellE85N9 Could you DM me a screenshot of your Fusion screen (like what's seen in this article: https://www.autodesk.com/products/fusion-360/blog/the-10-document-limit-for-personal-use-explained-i...) and your email address you use to login, if you're comfortable?
Brian Mark
Sr. Product Owner-Fusion Team
