Fusion 360 Search results are wrong - missing files
simon.dyer
Message 1 of 25
simon.dyer
The file search is very unreliable. Very frustrating when I want to find a file.  Please fix it.  I see this was last reported in 2019
Replies (24)
Message 2 of 25
billbedford
By default Fusion only searches in the current folder. To change it click on the grey box and choose 'All Data' or some other folder.
Message 3 of 25
rosie_lucas1
Hello @simon.dyer ,
Did the information provided by @billbedford help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
Message 4 of 25
simon.dyer
Thanks Bill. I usually search from AllData - As you can see from the photos I am demonstrating that the file exists and should show up in the search.
Message 5 of 25
simon.dyer
Hi Bill,
Even using All Data it cannot find my file(s) as you can see below:
Message 6 of 25
simon.dyer
HI Rosie,  I posted an additional image to demonstrate that it cannot find files, even when searching from All Data
Message 7 of 25
Andy.Spivey
Hi @simon.dyer,
Thank you for reporting the issue with your search results - sorry that you are seeing a problem here.  Can you send me a direct message with the email address associated to your Fusion account and we'll take a look and correct the issue?
Thank you!
-Andy
Andy Spivey
SQA Engineer
Message 8 of 25
Andy.Spivey
Hi @simon.dyer - can you check the search behavior now please?  Are expected files being returned when you search for them?
Andy Spivey
SQA Engineer
Message 9 of 25
simon.dyer
Hi Andy
Thank you for looking at this problem - how can I assist?
Message 10 of 25
Andy.Spivey
Can you please try searching again and see if the results are appearing as expected?  The search indexes were recreated for you hub.
Andy Spivey
SQA Engineer
Message 11 of 25
simon.dyer
Hello Andy,
Thanks for checking.  Unfortunately problem remains. Im running the Fusion update now - see if that helps.
Message 12 of 25
Andy.Spivey
Thank you @simon.dyer - I've asked the team to continue the investigation regarding.
Andy Spivey
SQA Engineer
Message 13 of 25
Andy.Spivey
Hi @simon.dyer - the team did another pass-through.  Can you check again please?
Thanks!
Andy Spivey
SQA Engineer
Message 14 of 25
simon.dyer
Hi Andy,
Problem is fixed.  I'm assuming all files can be found now. Is there something we users can do in future if the problem repeats?
Message 15 of 25
ChrisHeerschap
I'm seeing this as well. Searching for "Quarq" in All Data returns two items:
Choosing "Show in location" brings me to the folder which shows the thing I was actually looking for - second item - which should have been a match as well:
I've seen the same a couple other times recently but did not note the exact occurrences. Have seen exact matches not show up, and have seen partial matches not show up.
The only fix I've seen mentioned here appears to be messaging @Andy.Spivey - is that still what I'll need to do?
Message 16 of 25
spivey.andy
Hi @ChrisHeerschap - thank you for reporting the search issue you are seeing.
Can you send me a direct message with your email and I can look up your hub details?  We will get this looked into for you.
Thank you!
-Andy
Message 17 of 25
ChrisHeerschap
Sent, sorry for the duplicate, the first one did not seem to work.
Message 18 of 25
Andy.Spivey
No problem - I just noticed I had a different account logged in - got the message though.  I'll loop back once things are addressed.
Andy Spivey
SQA Engineer
Message 19 of 25
Andy.Spivey
Hi @ChrisHeerschap - can you check search now please?
Andy Spivey
SQA Engineer
Message 20 of 25
ChrisHeerschap
Still missing the one item - and this is the latest update, I restarted yesterday.
