download DXF file from a drawing
jean-michel_legoff
jean-michel_legoff
I've noticed in Teams, that when you browse drawings, you can only donwload them as DWG or PDF... but not DXF.
Dxf could be mandatory in some case when final user don't have Autocad.
PDF can't be used as the drawing is not exactly at the right dimensions.
For any reason there are some 1/10 mm in excess...
Many Thanks
jean-michel_legoff
in red the cotation from Adobe Illustrator...
there is 0,013 mm more than the 100mm
jean-michel_legoff
here is the PDF
jean-michel_legoff
in teams the dimension is 100.000
