Yet another CAM error
After having exported a file to EAGLE 9.6 format, and when I click on CAM processor, it refers to the EAGLE file name just exported, instead of what I have open in Fusion.
It gives this error message, and if clicking or anything, Fusion crashes.
The reason the files does not exist, is because I strip off the stupid version number as EAGLE wants both SCH and BRD files to be named the same.
It's interesting, that if you export to EAGLE 9.x, Fusion "processes" the filename and replaces spaces with underscores.
For no reason whatsoever. EAGLE 9 handles spaces in the filenames just fine.
Now, it would have been a LOT more useful if it had instead stripped off the version number.
Aaaand, here we have another bug.
The underscore thing, ONLY happens if you switch from some other file format to EAGLE 9.x format.
NOT if you open the dialog and it's already set to EAGLE 9.x.
This will happen if you, for instance, first save the schematic file, changing from the normally default Fusion Archive Format format to EAGLE 9.x. Underscores will the be added. When you then go to export the board file, it is already set to export to EAGLE 9.x and the underscores will NOT be added.
@jorge_garcia .....???
Do the developers ever test their work? Or to they just compile and ship?
Quality control on Fusion Electronics is just complete missing the mark.
I have NEVER, EVER seen a professional program crash so often and been riddled with this many bugs in a released version.
I have been in several beta tester groups of programs even bigger and more complex than Fusion, both open and closed source and there never were these constant crashes and errors.
Not only do we have to pay for it, but also spent countless hours with workarounds and reporting bugs.
