Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Working with multiple PCB in design
2 REPLIES 2
javiher9310
1215 Views, 2 Replies
Hi guys!
Has been kind of hard to adapt my self to the new integration of the electronics part into Fusion. But I think that worth the try. I've finished the design of two boards and now I'm working in the integration within the enclosure. But when I'm working in the file that has both designs when I go to the file of the PCB and made any change in the file that has all the designs doesn't move the components.
I attached some pictures I hope you can understand the situation. Any advice would be very appreciate.
Thanks!
Original PCB board fileOriginal PCB board fileFile with both boards and component with wrong position.File with both boards and component with wrong position.Component with wrong positionComponent with wrong positionComponentComponent
2 REPLIES 2
jorge_garcia2
in reply to: javiher9310
Hi @javiher9310,
I hope you're doing well. How did you join the two boards? We are looking at this type of issue to find a cause.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
javiher9310
in reply to: jorge_garcia2
Hi @jorge_garcia2,
I'm so embarrassed, I found that when I'm making the assembly if I "Capture the position", always that I update the design I have to revert this change, and after that the design is updated. Then I have to move it again to the place where it should be.
But thank you so much for answering!
