Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Working with differential pairs causing frequent crashes
2 REPLIES 2
joe.burks
97 Views, 2 Replies
For days I have been trying to route an HDMI signal across a board, but I cannot do so because Fusion 360 keeps crashing when I attempt to meander of otherwise match lengths of the differential pairs. I've attached an image showing what I'm working with. The most important thing to note is that there is ONE (1) routed differential pair. Attempting to meander that pair to length match the two traces generally doesn't work and when I try to do it manually, Fusion 360 seems to mess with me for a bit until just crashing again.
Apparently here my mouse pointer is NOT far enough away from the pair for it to attempt to meander:
Moving my mouse closer, however, is far enough away for F360 to attempt a meander:
Interestingly, the pre- and post- meander lengths are identical, despite both of them obviously increasingly in length. Also, the post- meander ratio is no better than the pre-meander ratio. I guess I'll have to do this manually:
I have not been able to get a single differential pair routed and matched WITH NO OTHER SIGNALS CONNECTED. I've been at this for days.
2 REPLIES 2
jorge_garcia2
in reply to: joe.burks
Hi @joe.burks ,
I hope this message finds you well. The issue you are running into aside, even if you could get all the signals routed they are all crossing over on each other, the signal integrity would be pretty bad and it's possible your design wouldn't even work. A better approach if possible for your application might be to have them mirrored one on the top of the PCB and one on the bottom.
That aside, would you be willing to share the files for review. I would definitely be interested in checking them out and having the developers find out what's causing the crash.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
panpan_fan
Hi @joe.burks
I hope you are doing well!
For the meander crash, we have fixed it in the latest version V2.0.14567.
Please update Fusion 360 and try again, thanks!
Panpan Fan
